JulietFalcon
Nov 10, 2020Aspirant
Orbi RBR20 slow upload speed
I have a 300 mbps internet service plan with Xfinity and am having issues maintaining proper upload speeds when I run speed tests. My download speeds are typically between 250-350 mbps, and upload sp...
JulietFalcon
Dec 02, 2020Aspirant
The modem manufacturer and model is Arris Surfboard SB6183. I am unsure how to check if armor is circle is enabled.
Once the update to firmware v2.6.1.36 was complete, resetting the modem and router seemed to fix our problems for the past couple weeks, but here we are again. Download speeds are fine, but upload speeds are back to 0.5 - 2mbps.
Dec 02, 2020Guru - Experienced User
If you have Armor enabled, it wil be on your mobile Orbi app and also appear on the RBRs web page as enabled on the first page if you look at the RBRs web page with a web browser.
- JulietFalconDec 06, 2020Aspirant
We do not have Armor activated on our device.
We have an Xfinity field technician coming tomorrow. I've spoken with Arris customer support and they've informed our downstream bonded channels are fine, but that our upstream bonded channels should be between 45-51 and our currently at 42. Arris also had me connect directly from the modem to my laptop, and the speed tests came back with the correct speeds which lead me to believe that there is an issue with the router, however, the Arris tech contined to say it is more likely the result of the upstream bonded channels power levels too low.
Any insight on this? We had a field technician come out about 6 months ago and informed of the upstream bonded channels being too low and they had no idea what I was talking about.
- FURRYe38Dec 06, 2020Guru - Experienced User
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
JulietFalcon wrote:We do not have Armor activated on our device.
- vajimDec 06, 2020Master
Was your slowdown before or after your fw update?
