Farhan24
Apr 25, 2020Aspirant
Orbi RBR20 Slow Wifi Speed
Firmware:2.3.5.30 Setup: Netgear 1000mbps modem, orbi, orbi sattelite, 8 port switch We have recently upgraded to 600mbps down from our previous 200mbps down. While wired directly into the orbi ...
Apr 25, 2020Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
Also there is newer v16 firmware available to try...
Farhan24
It is connected to a Netgear CM1000-100NAS modem no router built in. Orbi is in router mode. Approximately 2500 square foot house. Distance between the orbi and the satellite is between two opposite corners of 2 floors. Using auto channel for 2.4ghz and 5ghz. Next neighbors wifi is at roughly 50% within the house. Beamforming and mimo are on. Armor, circle, daisy chain, and ipv6 are already off. I will try adjusting the 20/40mhz setting and the preamble setting and come back with the results.
- SKR2710Jul 03, 2020Aspirant
Is this issue fixed for you? I am having the same exact problem with similar size home.
Farhan24 wrote:It is connected to a Netgear CM1000-100NAS modem no router built in. Orbi is in router mode. Approximately 2500 square foot house. Distance between the orbi and the satellite is between two opposite corners of 2 floors. Using auto channel for 2.4ghz and 5ghz. Next neighbors wifi is at roughly 50% within the house. Beamforming and mimo are on. Armor, circle, daisy chain, and ipv6 are already off. I will try adjusting the 20/40mhz setting and the preamble setting and come back with the results.
- FURRYe38Jul 04, 2020Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too?What is the size of your home? Sq Ft?
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
SKR2710 wrote:Is this issue fixed for you? I am having the same exact problem with similar size home.
- Farhan24Jul 14, 2020Aspirant
Changing the settings like was recommended did help a little bit but found myself unable to get more than 300mbps unless I was in the same room as the router. I'm convinced it's likely a limitation with wifi ac and the router to put out that kind of speed anything more than a room or 2 apart.
- FURRYe38Jul 14, 2020Guru - Experienced User
You would be correct in your thinking. :smileywink:
