liobod
Apr 20, 2020Guide
Orbi RBR20 SSH & vpn en échec
Bonjour, J'ai un soucis avec mon RBR20 firmware v2.3.5.30 : Celui-ci ne laisse passer aucune connexion (sortante) en SSH, ni ne laisse initier aucun tunnel VPN (OpenVPN) vers des équipements e...
- Apr 22, 2020
OK, After a few invastigation, i found out :
On the ISP box, when i disable IPv6, ssh(port 22) and VPN connexions can be established.
And don't ask why.
Thx for help
liobod
Apr 20, 2020Guide
Hi,
Got a problem with my RBR20 V2.3.5.26 :
It does neither let ssh connection go through, nor let VPN (OpenVPN) initiate toward externals devices.
However, these connections are ok when they do not use wifi networking :
- When i use my network directly wired on my ISP
- When i use my 4G mobile network
Just to let know : RBR20 has a single satelitte, no parental is activated, and it's in AP mode (no router mode)
Thx for your help,
Apr 20, 2020Guru - Experienced User
Are you sure the RBR is in AP mode? AP mode should be passing thru any and all traffic. IF the RBR is in router mode, then there maybe some problems.
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
- liobodApr 20, 2020Guide
If only it could be a clue :
Maker : Sagemcom
Model : Livebox 4
firmware : 3.73.8
firmware Orange(ISP : g0-f-sip-fr- FURRYe38Apr 21, 2020Guru - Experienced User
Ok was checking the ONT:
https://support.sagemcom.com/en/gateways/livebox-4?language_content_entity=en
I would open up a support tickect and ask NG support for additional help on this? The system should be passing thru any and all traffic while in AP Mode.
https://www.netgear.com/support/#
- liobodApr 22, 2020Guide
And don't ask why.
Thx for help
