liobod
Apr 20, 2020Guide
Orbi RBR20 SSH & vpn en échec
Bonjour, J'ai un soucis avec mon RBR20 firmware v2.3.5.30 : Celui-ci ne laisse passer aucune connexion (sortante) en SSH, ni ne laisse initier aucun tunnel VPN (OpenVPN) vers des équipements e...
- Apr 22, 2020
OK, After a few invastigation, i found out :
On the ISP box, when i disable IPv6, ssh(port 22) and VPN connexions can be established.
And don't ask why.
Thx for help
Apr 21, 2020Guru - Experienced User
Ok was checking the ONT:
https://support.sagemcom.com/en/gateways/livebox-4?language_content_entity=en
I would open up a support tickect and ask NG support for additional help on this? The system should be passing thru any and all traffic while in AP Mode.
https://www.netgear.com/support/#
liobod
Apr 22, 2020Guide
And don't ask why.
Thx for help
- FURRYe38Apr 22, 2020Guru - Experienced User
Interesting. Glad you found the fix and it works. Thank you for letting us know.
Enjoy.
