KBean
May 06, 2020Aspirant
Orbi RBR20 system not connecting with 2.4GHz devices
I have been trying to get an in home camera system set up and have so far tried 2 different systems. Neither will connect with the Orbi network I have set up. I am not tech illiterate, but the solu...
May 06, 2020Guru - Experienced User
Netgear provides a simple mechanism to accomplish this:
Log into the Orbi web interface (http://orbilogin.net)
Navigate to the Advanced Tab, Advanced Settings, Wireless Settings
Uncheck the box, "Broadcast SSID on 5G"
Click "Apply"
All devices that are currently connected to the Orbi will remain connected.
On the smartphone, go to wireless settings and "forget" the Orbi SSID
Search for available WiFi networks. Select the Orbi WiFi. Enter the password. and connect.
If you are curious about whether the smartphone is actually connected at 2.4G, you have to wait a few minutes, because the "Attached Devices" display takes a while to update.
Open the app and set up the 2.4G device.
Once the device is connected and working as it should, reverse the steps.
Check the "Broadcast" box and click "Apply"
"Forget" the Orbi WiFi. Search. Enter password. Connect.
Be aware that there seems to be a time limit with some iOS or Android devices that will connect to the 2.4Ghz radio for a short period of time before changing automatically to the 5Ghz SSID, even though it's been hidden. The SSID is hidden only, thus the signal is still present. So you might want to also change the power output of the 5Ghz radio to 25%. Then connect your mobile device at a distance from the RBR to ensure the mobile phone keeps connected to the 2.4Ghz radio. After you get the IoT device connected, re-configure the system back to where it was.
One other idea would be to use your prior 2.4Ghz router to setup the 2.4Ghz devices using same SSID name and passwork. Once it's setup using the old router, Turn OFF the old router and the devices should connect to the new Orbi router system.
- KBeanMay 14, 2020Aspirant
While this may have been a solution, what ended up happening is my Mac and Iphone both stopped connecting to the Wifi all together once I unchecked the 5G box. I then was no longer able to login to orbilogin.net no matter what browser I used or how far back I cleared the caches. So I ended up having to reset my entire network and try rebuilding it fresh, which, for some reason also didn't go well and had to be redone multiple times.
Ultimately, these cameras (one Netvue and one Yi system) should have set up as easily as my Ring doorbell did. So until there's one out there that does, I'm not even bothering.
Thanks for the attempts to help for those that answered.
- CrimpOnMay 14, 2020Guru - Experienced User
KBean wrote:Ultimately, these cameras (one Netvue and one Yi system) should have set up as easily as my Ring doorbell did. So until there's one out there that does, I'm not even bothering.
Is this Yi camera similar to the one you want to connect?
and, just to "double check" the WiFi password is not shorter than 8 or longer than 20 characters?
Setting Up Your Camera With YI Home App
1.Install YI Home App and create a YI Home Account
2.Power your camera on and click the icon on theupper right corner in YI HOME app to add your camera
3.Select your Wi-Fi network and enter your Wi-Fi password, then select Connect to Wi-Fi
4.Scan the QR Code shown on the app, then select Next once the QR Code has scanned
5.Select Save, then select Start using to finish pairing
6.If connection failed, please push the Reset button and try again
WiFi Settings
1.YI Home cameras will need to connect to a 2.4GHz band network. 5GHz WiFi band is not supported
2.Turning on the location service on the phone if you encounter Unknown SSID issue
3.Encryption mode must be set to WPA/WPA2 (mixed mode) or WPA2
4.Your Wi-Fi password must be 8-20 characters in length
If you have any other problem, please contact us via support@yitechnology.com.
- FURRYe38May 15, 2020Guru - Experienced User
It's recommended to have a wired PC onnected to the RBR while working with the wifi settings on the RBR.
KBean wrote:While this may have been a solution, what ended up happening is my Mac and Iphone both stopped connecting to the Wifi all together once I unchecked the 5G box. I then was no longer able to login to orbilogin.net no matter what browser I used or how far back I cleared the caches. So I ended up having to reset my entire network and try rebuilding it fresh, which, for some reason also didn't go well and had to be redone multiple times.
- CrimpOnMay 16, 2020Guru - Experienced User
I remain puzzled. Amazon delivered my Yi 1080p Home Camera today. Unboxed it. Loaded the Yi (pronounced "Yee") Android App. Started App. Plugged in camera. Followed instructions. Found the account creation process a bit tedious, but to be expected. Selected my Orbi WiFi while my phone was connected to the Orbi at 5G. Showed the QR code to the camera and "done". Connected. Streams picture. As I assumed, cameras do not care what "band" the app is connected to because they get the WiFi SSID and password from the QR code. The $22 cost created that much enjoyment for me and the camera now goes "into the box of things that work."
So, every camera that I have purchased has connected to my Orbi WiFi by scanning a QR code. No problem. Maybe there is a quirk in the iPhone version of the app that causes a hangup somewhere. (Do I dare ask to borrow the wife's iPhone to test? Maybe when she's asleep.)
