KBean
May 06, 2020Aspirant
Orbi RBR20 system not connecting with 2.4GHz devices
I have been trying to get an in home camera system set up and have so far tried 2 different systems. Neither will connect with the Orbi network I have set up. I am not tech illiterate, but the solu...
KBean
May 14, 2020Aspirant
While this may have been a solution, what ended up happening is my Mac and Iphone both stopped connecting to the Wifi all together once I unchecked the 5G box. I then was no longer able to login to orbilogin.net no matter what browser I used or how far back I cleared the caches. So I ended up having to reset my entire network and try rebuilding it fresh, which, for some reason also didn't go well and had to be redone multiple times.
Ultimately, these cameras (one Netvue and one Yi system) should have set up as easily as my Ring doorbell did. So until there's one out there that does, I'm not even bothering.
Thanks for the attempts to help for those that answered.
May 15, 2020Guru - Experienced User
It's recommended to have a wired PC onnected to the RBR while working with the wifi settings on the RBR.
KBean wrote:While this may have been a solution, what ended up happening is my Mac and Iphone both stopped connecting to the Wifi all together once I unchecked the 5G box. I then was no longer able to login to orbilogin.net no matter what browser I used or how far back I cleared the caches. So I ended up having to reset my entire network and try rebuilding it fresh, which, for some reason also didn't go well and had to be redone multiple times.
