jlurbanik
Dec 27, 2019Guide
Orbi RBR20 unstable internet during video calls
Using an Orbi RBR20 AC2200 and Spectrum cable internet for my home office. 99% of the time it works great but during video calls using Zoom, esp. with more than 5 ppl on the call, I get an warning m...
jlurbanik
Jan 02, 2020Guide
Thanks for the detailed reply.
I have the latest firmware (V2.3.5.26) - did a check for updates and I'm up to date
The modem is from Spectrum (couldn't find a mfr), Model E31T2V1
2600 SF home, satellite probably 15-20 feet away from router. it is on 2nd floor by my office, Router is one floor below about 2 feet from cable modem. standard wood stud/drywall construction - no stone or brick between the floors.
Currently on channel 8 for 2.4Ghz and channel 40 for 5 GHz. how can i find out if a channel is unused? I have tried various combinations of channels in the past. some work better than others.
bunch of wifi neighbors - at least 10 show up when i look
i enabled Beamforming and MIMO. WMM already enabled.
Armor and Circle and fast roaming and IPv6 already disabled. did not change Daisy Chain because when i saved other changes, the system lost the IP address and locked up until I reset everything. not anxious to go thru that again. The 20/40 Mhz coexistence is checked but i don't see a way to set it to 40 Mhz only. how do i do that?
thanks for your help. i have a small video call tomorrow and a bigger one next week. will see how it behaves.
albertopm
Jan 09, 2020Guide
I'm experiencing similar issues:
- unstable network errors and interruptions during Zoom calls
- other apps seem to work fine, when doing VoIp calls on Telegram, Facetime, Whatsapp etc. I do not experience such issues, although I suspect it's because Zoom is more demanding in terms of bandwidth due to video streaming
- happens on wifi, using wired Ethernet cable connected to the Satellite I never have any issues
- I have tried changing most settings as suggested but still happening
- I have just changed to a new 2.4Ghz channel to see if it helps, but I don't think it's that. I don't have many wifi networks and there are no channel collisions whatsoever.
My setup:
- Netgear Orbi RBR50 — Orbi AC3000 Tri-band WiFi Router
- Latest firmware (V2.3.5.30)
- Satellite on wired backhaul connection
I have just realized I have double NAT - my ISP router is doing NAT + Orbi is doing NAT. Could this be related, perhaps?
I haven't experienced any issues with downloads, Netflix streaming or playing videogames on PS4.
Any pointers appreciated.
- albertopmJan 21, 2020Guide
I resolved the double NAT issue by configuring the ISP router in bridge mode, but I'm still experiencing these issues.
