Retired_Member
Jan 10, 2021Orbi RBR20 v2.6.1.36, bug in IPv6 over PPPoE WAN remains.
On set 14th 20 I reported a bug on IPv6 over PPPoE WAN connection cause by wrong TCPMSS / MTU afecting my Orbi RBR20 v2.5.1.16, it cause and some insights about how to fix it. On that time the same b...
Jan 10, 2021Guru - Experienced User
Sonething to keep in contact with NG support. Nothing we can do here in the forums.
Good Luck.
Retired_Member
Jan 17, 2021Unfortunately, when I typed router serial number I was informed that my hardware is under warranty, but my 90 days complementary technical support has ended, so I'm unable to open a ticket on NG support.
:smileysad:
