kevinscott
Jun 27, 2022Tutor
Orbi RBR20 VPN not assigning IP
Orbi RBR20 Router Firmware Version V2.7.4.24 I'm able to connect using OpenVPN and Tunnelblick, but it's not using my home's IP Address. Any suggestions? Thanks
CrimpOn
Jun 27, 2022Guru - Experienced User
Can you please explain more about "my home's IP address"
My Orbi LAN subnet is 192.168.1.x.
When I connect to the Orbi VPN, the device connecting is assigned an IP address of 192.168.2.x.
That means that Ethernet broadcast packets do not cross the VPN tunnel (in general a good thing).
There is an implied static router between the VPN tunnel and the Orbi LAN, so that I can reach any device on the LAN by its IP address.
kevinscott
Jun 27, 2022Tutor
I thought that when connecting to the vpn on my router at home, I'd be accessing the internet as if I was at home.
when I check to see what my ip address is in a brower using a site like whatismyip, I'm not getting my home ip address.
When using tunnelblick I get the message "this computer's apparent public ip address was not different after connecting to client"
Just for context, I'll be traveling internationally soon and need access to US websites that might have an international block on them. Thank you for the help
- CrimpOnJun 28, 2022Guru - Experienced User
(Not being an Apple person....) Some VPN clients have an option for whether ALL traffic goes through the VPN tunnel or just part of it.
suggest looking at Tunnleblick settings.
- kevinscottJun 28, 2022Tutor
In the Tunnelblick configuration "Route all IPv4 traffic through the VPN" is set.
In the OpenVPN app, I don't see any setting like that.
Yes, I'm using Tunnelblick on a macbook pro, and the OpenVPN app on a iPhone and iPad
Well.... this is a mystery.
I turned off WiFi on my phone and activated the WiFi Hot Spot.
Connected three different user devices to the Hot Spot:
- Windows 10 laptop
- Linux Mint laptop
- Android Tablet (Samsung Galaxy S6lite)
Activated the OpenVPN app on all three.
- They all appeared on the Orbi Attached Devices screen as 'vpn' and had IPs of 192.168.2.x
- When I opened a "What is my IP?" web page, all three showed the public IP of my Orbi router.
(Not the IP of my smartphone.)
How are you testing OpenVPN connections?
- Smartphone Hot Spot?
- Coffee shop?
- Friend or work network?
