missourimace
May 28, 2020Follower
Orbi RBR20 wifi drops in and out after update
I have had my RBR20 for a couple months. It seems to work fine but then the wifi just drops out and everything connected to it drops out. I had a trouble ticked but I didnt realize they had time limi...
May 28, 2020Guru - Experienced User
