Ashraful
Feb 08, 2020Tutor
Orbi RBR20 Wifi Freezes repeatedly
Hello. I am using an ORBI RBR20 router. Specifications are provided below. My issue: My interent connectivity freezes up 4-5 times a day. The ISP provided fiber optic modem has connectivity dur...
Feb 08, 2020Guru - Experienced User
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
