joeyruan
Nov 23, 2018Tutor
Orbi RBR20 Wifi Sucks
I have had the Orbi RBR20 from Costco for a few months now and I have to say it sucks.Originally we had the satellite dropping the connection from the router ever minute. That was bad enough. Now we ...
- Nov 24, 2018
Try testing with the satellite OFF.
20 feet maybe too close. What is the signal of the satellite seen on the satellite? Good, Bad?
If you tring AP mode, the modem should have been in router mode and the Orbi in AP mode should have been passed internet traffic. DMZ will not be used in this mode on the modem.
For Apple wireless issues:
Advanced Wireless Settings both 2.4GHz and 5GHz changed CTS/RTS Threshold to 2307.
https://community.netgear.com/t5/Orbi/Orbi-RBR40-RBS40-V2-1-4-16-mesh-network-drops-connection-to/m-p/1601598/highlight/true#M35230
https://community.netgear.com/t5/Orbi/Have-to-keep-rebooting-my-RBR50/m-p/1658603/highlight/false#M44420
Change the CTR/RTS threshold values for both 2.4 GHz and 5 GHz (2341 and 2345 respectively), changed preamble modes to long preamble, and Set 20/40Mhz Coexistence to 40Mhz only.
joeyruan wrote:
So first of all, my apple tv is more stable when my modem wifi is on so any other options? Also, any solutions for bufferbloat or should I open a different topic about that?
Nov 24, 2018Guru - Experienced User
the DMZ is for passing as much traffic as possible thru the modem to the Orbi router in router mode. It can be used when the modem can't be fully bridged.
joeyruan
Nov 24, 2018Tutor
- ekhalilNov 24, 2018Master- What wired devices do you have connected to Orbi?
- Do you see the bufferbloat issue from specific devices or all? Devices connected to satellite or even router?- joeyruanNov 24, 2018Tutor
ORBI Router:
- Laptop
- Modem/Router/NAS
- Apple TV
- Switch: Arlo, Powerline
- Powerline: Dell Laptop, 2 Printer
All devices from Android, iOS, and Windows. It affects my gaming too. It doesn't matter if it's satellite or router, it's always present.
- ekhalilNov 24, 2018MasterAre you sure all your devices and Orbi base stations on the same IP network? Please check this.
- FURRYe38Nov 24, 2018Guru - Experienced User
For the Apple TV, it’s actually a iTalkBB. Basically an Apple TV but Chinese. Should I still use the settings that you recommended?
u can use the suggestions, if you don't notice any change in behavior you can revert back to default settings.
