BellaNZ32
Nov 22, 2019Aspirant
Orbi rbr20 will not connect to internet
My Orbi was working fine and then it started dropping the internet intermittently. Unplugging it and plugging it back in seemed to work for a while but now it doesn’t as the internet keeps showing as ...
Nov 22, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Has a factory reset and setup from scratch been performed since last update?
- BellaNZ32Nov 22, 2019AspirantFirmware is V2.3.5.26, I connected the orbi via my old ISP router (which I unplugged again now....internet works fine with that one) and then I logged into orbi online and checked for new firmware, nothing was available so I assume I have the latest.
- FURRYe38Nov 22, 2019Guru - Experienced User
So i you have a router in front of the Orbi RBR, you might try changing the RBR to AP mode instead of router mode. Having to routers on the same line can cause problems.
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly. Then use the Orbi router in router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopWhat is the Mfr and model# of the ISP modem?
- BellaNZ32Nov 22, 2019AspirantNo I don’t have the ISP router turned on, I just plugged it in to see if there was an issue with my external line or ISP fibre connection. it worked fine so must be the Orbi. It’s disconnected now as the Orbi has been fine (until now) without running through the ISP modem/router I assume I don’t need it plugged in or bridges as the Orbi should just work like it was before?
The ISP modem is a Vodafone Ultra Hub plus.
- BellaNZ32Nov 22, 2019AspirantI’m not connecting via the ISP modem as it’s also a router and messes with the mesh WiFi signal, the Orbi Internet port is connected directly to my fibre box which are right next to each other
- CrimpOnNov 22, 2019Guru - Experienced User
BellaNZ32 wrote:
I’m not connecting via the ISP modem as it’s also a router and messes with the mesh WiFi signal, the Orbi Internet port is connected directly to my fibre box which are right next to each otherCan you provide the brand/model number of the fiber box?
- BellaNZ32Dec 01, 2019AspirantThe Fibre box is a “Optimal Network Terminal” that is installed by Chorus, all Fibre installations in New Zealand are carried out by chorus so must be the standard install that everyone has.
- BellaNZ32Nov 22, 2019AspirantHouse is about 260 square
Satellites are a good distance apart
I think I am using auto, not sure where to check this or how to change it but while playing with things for about 5hrs I saw a lot of auto settings
There’s only one neighbor within range showing as another WiFi connection option
The factory reset was set up from scratch has just been done, twice
