BellaNZ32
Nov 22, 2019Aspirant
Orbi rbr20 will not connect to internet
My Orbi was working fine and then it started dropping the internet intermittently. Unplugging it and plugging it back in seemed to work for a while but now it doesn’t as the internet keeps showing as ...
Nov 22, 2019Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Has a factory reset and setup from scratch been performed since last update?
BellaNZ32
I’m not connecting via the ISP modem as it’s also a router and messes with the mesh WiFi signal, the Orbi Internet port is connected directly to my fibre box which are right next to each other
- CrimpOnNov 22, 2019Guru - Experienced User
BellaNZ32 wrote:
I’m not connecting via the ISP modem as it’s also a router and messes with the mesh WiFi signal, the Orbi Internet port is connected directly to my fibre box which are right next to each otherCan you provide the brand/model number of the fiber box?
- BellaNZ32Dec 01, 2019AspirantThe Fibre box is a “Optimal Network Terminal” that is installed by Chorus, all Fibre installations in New Zealand are carried out by chorus so must be the standard install that everyone has.
