ddjeff
Aug 27, 2020Aspirant
Orbi RBR20 with AT&T internet
Sorry if this has been asked before but I just got ATT internet and I noticed that my orbi (when plugged into the provided att router/modem) shows the RBR as a magenta color and the RBSs as green. All...
- Aug 27, 2020
Any of those 3 should work.
What I'd recommend? it'd be based on your capabilities.
If you don't use the orbi's parental controls or other features, just put it in AP mode.
If you use them. Then try the passthrough or dmz option.
Aug 27, 2020Guru - Experienced User
its because att installs modem/router combo devices.
it puts you in a double nat. https://kb.netgear.com/30186/What-is-Double-NAT
options?
1. put the orbi in access point mode
2. put the att router in passthrough/modem only mode
3. put the orbi in the att's devices DMZ
ddjeff
Ok thanks, which would you recommend if those three? Or did you mean try them in that order?
- plemansAug 27, 2020Guru - Experienced User
