Jason-B's avatar
Jason-B
Follower
Apr 03, 2020
Orbi RBR20 with satellite issues
I have a brand new Modem from my ISP and I purchased a brand new Orbi RBR20 router that came with a satellite.  I have placed the satellite in several different loctaions well within range of the main router.  For whatever reason, most all devices wanna connect to the satellite.  Very few will connect to the main router.  Our 60" TV is 3 feet away from the main router but still connectes to the damn satellite that is 20 feet or so away.  Also when this is happening the signal bars are very low and our connection drops constantly.  I removed the satellite from the picture and allowed everything to connect to the main router.  So far this has been A LOT better.  My question is why does everything appear to travel through the satellite? Can I force an electronic to connect where I want it to connect.  Just frustrated to say the least.  I spent a couple hundred on this NETGEAR ORBI AC2200 tri-band wifi router and was expecting less hassel.  If someone can help me understand this, please do.  And yes, I have updated the firmware etc.
1 Reply
  • FURRYe38's avatar
    What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
     Might move the RBS farther away from the TV.
    Wireless devices will pick and chose which signal source to connect too.
