quidnunc
Aug 20, 2019Initiate
ORBI RBR20 won't daisy-chain wirelessly
I have a new Orbi RBR20 router with 2 satellites. As we have a long thin house, I wanted to set up a daisy-chain: Router to Satellite 1 to Satellite 2. But currently the network is a star system -...
- Aug 21, 2019
Ya, someone you talked to wasn't fully up to date or got sided tracked.
Glad the power ON process worked. Please mark your post thread as solved so other will know.
Enjoy. :smileywink:
quidnunc
Yes, that worked by unplugging the power lead then plugging it back in, rather than just using the SYNC button.
The network setup seems to be very sequentially oriented:
Everything off. Then power router on, and wait ........ Then power Satellite 1 on and wait ...... Finally power Satellite 2 on and wait ......
Thanks for the help.
Had just spent almost an hour on the phone to Netgear support, who were adamant that I had to put a cable between the two satellites. And that was despite me telling them that the Netgear web site clearly showed that daisy-chaining was now an option, over the star setup.
Aug 21, 2019Guru - Experienced User
Enjoy. :smileywink:
