td18
Oct 17, 2019Aspirant
Orbi RBR20
Just installed my Orbi and having issues with some devices not connecting. My laptop seems to work fine, but my Alexa and Netflix cannot connect to the internet. On the Orbi app, it indicates a connection but says the internet is offline. I need instructions to fix please. Not a tech savvy guy.
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here already? If so, This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop- td18Aspirant
Firmware is V2.3.5.26 on the Orbi RBR20
Purchased the Orbi Mini AC2200 Tri-Band 2-pack from Costco.
https://www.costco.com/Netgear-Orbi-Mini-AC2200-Tri-Band-Wi-Fi-System,-2-pack.product.100398382.html
