skymetal
Feb 15, 2020Aspirant
Orbi RBR20
I switched internet providers and purchased a Nighthawk X6S AC4000 wifi router. I also previously had the Orbi RBR20. The orbi is not connecting or meshing with my new nighthawk. Can anyone tell m...
- Feb 17, 2020I ended up calling customer service and had to purchase a plan to get help. Had to reset the orbi router and do the manual setup on orbionline.net. got it to work
CrimpOn
Feb 17, 2020Guru - Experienced User
Perhaps this is it: https://www.amazon.com/NETGEAR-Nighthawk-Tri-band-Ethernet-Compatible/dp/B072LZZZXB
Certainly a combination router/WiFi.
skymetal
Feb 17, 2020Aspirant
- FURRYe38Feb 17, 2020Guru - Experienced User
Ok. Glad you got it working. Please mark your thread as solved so others will know.
Enjoy. :smileywink:
