rfareti
Mar 28, 2020Follower
Orbi RBR20
Earlier today my computer kept disconnecting and reconnecting to my Orbi and then finally it would stay connected but their was no internet access so I still couldn’t use the web. I check the orbi app and in the top right I see Internet: Offline even though my actual xfinity router had perfectly fine internet. In the app, I checked the Network map and I see a magenta dot to the left of the RBR20 router but my Satellite had a green dot. I tried the new setup method but same issue. Can’t use orbilogin to see if I need to switch to AP mode( which I have no idea what it is I just saw that people said that switching to it helped). Do I need to try syncing up the router and satellite? Maybe a new Ethernet cable? Any help would be appreciated.
1 Reply
What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopWhat is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
