NickJsy's avatar
NickJsy
Orbi RBR20
Hi, I have an Orbi RBR20 and RBS 20.  Given the layout of the house, I want to move the Orbi RBR20 about 10 m (30 ft) from the broadband router.  I presume I can use an ethernet cable, but want to check what type of ethernet cable and if there is a limit on the length.
Thank you
  • Cat 5e, cat 6, or greater would all work and are rated for 100m. so 10m isn't going to be an issue
  • plemans's avatar
    • NickJsy's avatar
      NickJsy
      Thanks for the quick response, much appreciated.
