CaboBon
Jul 28, 2020Aspirant
Orbi RBR20
I have had an Orbi router and 1 satellite for 2 years. Out of the blue, last night my Iphone lost connection to the Orbi network. I have tried everything to reconnect and have not had any luck.Help p...
DarkNet
Jul 29, 2020Apprentice
Does your iPhone recognize other wireless networks and can you successfully log in to one of them? Do you have any other wireless devices at home that can or cannot connect via wifi to your Orbi? I think you covered this but did you try “Forget This Network” in your iPhone and then attempt to reconnect?
- CaboBonAug 05, 2020Aspirant
Hi yes I did do the Forget this network think, and my Iphone has connected to another network. All other devices have been and are still connected to the Orbi network. My phone was too until it stopped. I have tried numerous times to get it to connect back but no luck. I will likely try to reset it to see if that works. I have been reluctant to do that because I have Arlo cameras set on the network. Would really be unhappy if I caused a bigger problem.
Thanks
