CaboBon
Jul 28, 2020Aspirant
Orbi RBR20
I have had an Orbi router and 1 satellite for 2 years. Out of the blue, last night my Iphone lost connection to the Orbi network. I have tried everything to reconnect and have not had any luck.Help p...
CaboBon
Aug 05, 2020Aspirant
Hi yes I did do the Forget this network think, and my Iphone has connected to another network. All other devices have been and are still connected to the Orbi network. My phone was too until it stopped. I have tried numerous times to get it to connect back but no luck. I will likely try to reset it to see if that works. I have been reluctant to do that because I have Arlo cameras set on the network. Would really be unhappy if I caused a bigger problem.
Thanks
Aug 05, 2020Guru - Experienced User
As long as you use the same SSID name and password for the wifi, your wifi devices will reconnect on there own.
