Tizman1
Dec 28, 2020Follower
ORBI Rbr20
Probably an easy solution but my buddy that set-up my original system died of Cancer a week ago. I am techno challenged and need simplified help? I can't access the 2400 side of my ORBI system and ha...
- Dec 28, 2020
You'll need to factory reset the RBR and RBS and setup from scratch. Press the reset button on the back of the RBS and RBR for 15 seconds then release.
Use a wired PC for best access with a web browser connected to the RBR and navigate to Orbilogin.com or 192.168.1.1. Walk thru the setup wizard here.
Dec 28, 2020Guru - Experienced User
