brycarp
Nov 25, 2018Follower
Orbi RBR40 - Login lockout after incorrect password attempts?
I had not logged into my central Orbi router (RBR40) for several months. I thought I could remember or soon guess what admin password I had used. I had no success, so then I checked in a place I migh...
Chitowndude
May 11, 2019Star
This message response won't let me set RBR40 as the Model I have. It's like it's invisible.
The fact is the RBR40 series has serious issues with the password and "saved questions". I DID write this information down. I KNOW what my password and answers to questions are.
And yet I routinely cannot login to this **bleep**ty system despite a number of firmware upgrades (including TWO this last week, the first of which was a huge problem as apparently Netgear found out after shoving it into our systems).
May 13, 2019Guru - Experienced User
Factory reset the router using the back push pin button. Hold it in until the top led turns on AMBER then let go. Wait for the WHITE led to slowly pulsate, then log in to orbilogin.com using a web browser and walk thru the setup wizard.
- Horn43Jul 03, 2019Aspirant
I’m having the exact same issue. My RBR40 with 3 satellites I set up last week I’m finding is giving me problems. Some websites I try to go to ask for the username and password along with a message that it will send it non-encrypted. In fact, the Apple App Store won’t work either.
Some reading is telling me that I need to turn off the WiFi from my modem in addition I need to turn my Orbi router to an access point. In order to change it to an AP I have to login to Orbilogin.com.
When I try to log in at orbilogin.com it won’t accept my username and password.
I reset the whole system using a paper clip to depress the button in the back till the amber light glowed and reset up the whole system from scratch.
And you guessed it, I wasted all this time and still get the same issue. I can not log in to Orbilogin.com
I’m about to throw this crap away, cut my losses, find an alternative and tell everyone I know to not waste their time on Orbi.
- FURRYe38Jul 03, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Horn43 wrote:I’m having the exact same issue. My RBR40 with 3 satellites I set up last week I’m finding is giving me problems. Some websites I try to go to ask for the username and password along with a message that it will send it non-encrypted. In fact, the Apple App Store won’t work either.
