nleaphart
Jan 18, 2018Follower
ORBI RBR40 - no wifi broadcast
I have an ORBI RBR40 with two satellites. Today, it suddenly stopped "broadcasting" a wifi signal. I used my old router and it works, so no problem with cable modem. I tried factory resetting and ...
DarrenM
Jan 22, 2018Sr. NETGEAR Moderator
When factory resetting the device make sure to hold the reset button for 10+ seconds the power light should go orange. If that does not work I suggest contacting support.
http://www.netgear.com/support/contact.aspx
DarrenM
