Bonzoid
Jun 15, 2019Aspirant
Orbi RBR40 - not able to switch to AP
The instructions for 'logging into the router' to change it to AP are incorrect on this site and elsewhere. I cannot log into the orbilogin.com using 'admin' or 'passord' or my Netgear login or ANYTH...
Jun 15, 2019Guru - Experienced User
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
I would factory reset the RBR and wire connect a PC to the RBR and walk thru the setup wizard, this time write down all important information. You should be able to access the UI and advanced tab/advanced settings/router and AP mode. I would not have the RBR connected to the ISP modem during this process...
