Bonzoid
Jun 15, 2019Aspirant
Orbi RBR40 - not able to switch to AP
The instructions for 'logging into the router' to change it to AP are incorrect on this site and elsewhere. I cannot log into the orbilogin.com using 'admin' or 'passord' or my Netgear login or ANYTH...
Bonzoid
Jun 16, 2019Aspirant
This is the best answer yet...in plain English you point out the problem: that Orbi needs to be configured first. Not a mention of that in any instructions I’ve seen. I knew I was doing something wrong (but you gotta admit those log in instructions are headscratchers for a novice!). Appreciate the step by step and the links, I’ll give it another go.
What about the separate WAP that came with the AT&T router? That should be left out of the equation, yes? Seems if Orbi is my WAP why would I use theirs?
Again, my thanks!
Again, my thanks!
michaelkenward
Jun 17, 2019Guru - Experienced User
I don't know what you read, but it is clearly – well sort of clearly – laid out in the manual in the section I pointed to, which is all about Access Point mode.
It is impossible to say anything about this based on the minimal information you have provided. Your first message is all rant and minimal detail, with a failure to understand what a WAN or LAN port looks like. Not a good start for anyone trying to help.
What is this AT&T router? What is this "separate WAP"? The model numbers?
FURRYe38 did ask.
We don't really know why you want to put the Orbi into AP mode.
