martkaufman
Apr 03, 2020Tutor
ORBI RBR40 - Separate SSIDs for 2.4 and 5 GHz?
 Box calls it an RBR40 Router - When setting up my WiFi SSIDs, can I differentiate between the 2.4 GHz and 5 GHz bands?  The App and the User Manual are not at all clear on that.  I have some devices ...
Apr 03, 2020Guru - Experienced User
You can reduce the power of the 2.4Ghz radio to help see if this makes some devices use 5Ghz.
Under Advanced Tab/Advanced Settings/Wireless Settings
martkaufman wrote:Box calls it an RBR40 Router - When setting up my WiFi SSIDs, can I differentiate between the 2.4 GHz and 5 GHz bands? The App and the User Manual are not at all clear on that. I have some devices that can only use the 2.4 GHz and I like to shift most everything else to the 5 GHz.
