martkaufman
Apr 03, 2020Tutor
ORBI RBR40 - Separate SSIDs for 2.4 and 5 GHz?
Box calls it an RBR40 Router - When setting up my WiFi SSIDs, can I differentiate between the 2.4 GHz and 5 GHz bands? The App and the User Manual are not at all clear on that. I have some devices ...
martkaufman
Apr 06, 2020Tutor
Many thanks to all who replied! Set up and running under one SSID. Everything seemed to connect OK. When looking in the Web portal, connections shows devices evenly connected to 2.4 GHz and 5 GHz. No other problems I can determine at this time.
Thanks again!
