jhorbi's avatar
jhorbi
Follower
Dec 09, 2019
Orbi RBR40 / RBS20 slow wifi connection
Purchased RBR40 w/ 2 RBS20 sats in June, since have seen significant drops in wifi speed.  Using Spectrum 200 ISP getting 230 download and 23 upload from modem.  Speed Test gives me 15-25 down over wifi, this use to be significantly higher. Have updated FW to 2.3.5.34 with no change in speed.  Any suggestions????
1 Reply
  • FURRYe38's avatar
    Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
