peter_peterson
Jan 10, 2023Aspirant
Orbi RBR40 + RBW30s dropping connection - what is optimal layout?
Hello friends! I am experiencing regular WiFi dropouts on my Netgear Orbi setup in a multistorey illustrated in the attached drawing. The RBW30s are directly vertical to each other on each floor with...
peter_peterson
Thanks very much for the help. I've moved my setup to something like the attached drawing now. The signals show as "good" on the network map but 1. devices like the one indicated on the ground floor have very low signal (yet it's attached to the 1st-floor satellite and is fairly close by). 2. The 2nd-floor satellite still connects to the main router, this may be fine that it is connected but I don't think this is passing the optimum signal up the house as its speeds are way slower at this distance. Should the satellites ideally be daisy-chained when in a tall house?
Can we better measure the link between the satellites beyond the Netgear color coding red/yellow/green?
When you say a donut, I understand you mean like a figure "8" but sideways, meaning directly above and below is the weakest.
CrimpOn
Jan 10, 2023Guru - Experienced User
Very good questions.
Daisy Chain is not 'preferred'. It is sometimes the only way a satellite can get a strong enough signal. (As in this case.)
Define "fairly close by". WiFi is affected by distance and building materials. I once had an ideal location for a security camera, but then realized that the path to the WiFi access point went through about 10 2x4 studs. (The camera was up against one side of the wall and the access point was about 15 ft. away next to the other side of the same wall.) Going through a bunch of bricks would not be good for the WiFi signal.
Strange that you should ask. On the original Orbi, there is a telnet command that displays the exact signal level and transmittion rates between Orbi units. Netgear removed telnet from the product over a year ago (maybe longer?) There is a program on the internet that will enable telnet at https://github.com/bkerler/netgear_telnet (This is not a trivial exercise.) After logging in with "admin" and the admin password, type the command:
satelliteinfo wifi
Like a do nut lying flat, yes:
