Bobby2shoes
Feb 12, 2019Initiate
Orbi RBR40 2 satellites hard wire internet works but WiFi does not.
I have an orbi rbr 40 and it is hooked up to a Xfinity modem. When I use an Ethernet cable from the Xfinity modem to the computer the internet works. When I have the orbi correctly set up and I connec...
- Feb 13, 2019Ok this is solved.
It was a problem in dealing with Xfinity.
They needed to reset some of the settings that got changed after a power outage and now the system works great.
Essentially the Xfinity modem was acting as a router and not allowing the ORBI to do so.
Hope this helps.
Feb 12, 2019Guru - Experienced User
What FW is currently loaded?
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here by chance?
Ensure the modems wifi is disabled if the modem has built in wifi.
Any other wifi devices near by?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using?
Try enableding Beamforming and MIMO.
Bobby2shoes wrote:
I have an orbi rbr 40 and it is hooked up to a Xfinity modem. When I use an Ethernet cable from the Xfinity modem to the computer the internet works. When I have the orbi correctly set up and I connect an ethernet cable from the orbi to the computer the internet works.
But for some reason the WiFi aspects of the orbi will not work. It will not let devices connect and the color on top is solid magenta which means no IP address but the internet works when hard wired into the orbi.
The orbi is in AP mode and the internet status says not connected when logged into the orbi, but again hard wire works and WiFi doesn’t . Please help.
Thank you
- Chuck_MFeb 13, 2019Mentor
Has the Orbi ever worked properly (wirelessly)?
If not -- or you are not sure -- chances are it has never been configured properly for your location.
If it has worked until recently, can you attribute any action to its failure?
Your clear answer to these two quesitons will be critical before any assistance can be given.
- Bobby2shoesFeb 13, 2019InitiateOk this is solved.
Hope this helps.- FURRYe38Feb 13, 2019Guru - Experienced User
FYI about Modem Combo Units:
This would be a double NAT condition which isn't recommended. Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Glad it was a ISP issue. Please mark your post thread as solved so others will know for future reference.Enjoy. :smileywink:
Bobby2shoes wrote:
Ok this is solved.
Hope this helps.
