Bobby2shoes's avatar
Bobby2shoes
Initiate
Feb 12, 2019
Orbi RBR40 2 satellites hard wire internet works but WiFi does not.
I have an orbi rbr 40 and it is hooked up to a Xfinity modem. When I use an Ethernet cable from the Xfinity modem to the computer the internet works. When I have the orbi correctly set up and I connec...
  • Bobby2shoes's avatar
    Bobby2shoes
    Feb 13, 2019
    Ok this is solved.
    It was a problem in dealing with Xfinity.
    They needed to reset some of the settings that got changed after a power outage and now the system works great.
    Essentially the Xfinity modem was acting as a router and not allowing the ORBI to do so.
    Hope this helps.
