videoscenes
Jul 22, 2019Aspirant
ORBI RBR40 and Direct TV STREAMING
Hey There ; I own the ORBI RBR40 with 2 satellites. ATT UVERSE GATEWAY, DIRECT TV (Genie) My only issue is when attempting to stream with Direct TV (channel 1000) or selecting a streaming program f...
CrimpOn
Jul 22, 2019Guru - Experienced User
videoscenes wrote:ATT tech came over and directly connected the Direct TV DVR system to internet, so the DVR is now receiving a direct internet signal. I believe he used "MOCA" to do this. So, theoretically, the DVR is receiving a hardwired internet signal. NOT WIRELESS. The problem STILL persists.
Not having Direct TV, perhaps you could explain what the DVR is streaming to? i.e. a television that is cabled to the DVR? Something else (like a PC)?
Are the Direct TV DVR and the television connected to the same coax cable?
videoscenes
Jul 25, 2019Aspirant
Hey there....
All connected to same cable. The main DVR is connected to internet via hardwire. Streaming is over internet from DTV servers. Internet is fed to home via fibre optics and to the ATT modem via bridge mode. Orbi gets fed signal from ”ATT modem in bridge mode. So....ATT MODEM is used as Gate to internet and nothing else. Orbi takes care of routing and feeding appliances. Streaming seems to have some kind of ”invisible link” or proprietary dependence on ATT modem hardware or software. Doesn't seem to wanna play nice and let orbi do the routing. Keeps dropping internet connection. At least that's what software on TV reports. I don't think it's REALLY dropping signal. I think the streaming signal is expecting something it's not getting via the Orbi.
- FURRYe38Jul 26, 2019Guru - Experienced User
What happens if you put the IP address for the DVR into the Orbis DMZ?
videoscenes wrote:Hey there....
- GoonieFanJan 07, 2020AspirantI have the same exact issue, where I have intermittent freezing on Direct Tv every minute or so. It seems the ORBI and Direct Tv are not getting along. Does anyone have a solution for this?
