OrbiOwner20
Mar 27, 2020Follower
Orbi RBR40 and IoT VLAN
Hi, I’m looking to set up a separate VLAN for one of the wired ports on an RBR40 for IoT devices so they’re isolated from the rest of my Wired network and can just get out to the internet. After mu...
Mstrbig
Aug 24, 2020Master
orbilogin.com - Advanced tab - Advanced setup - VLAN/Bridge Settings.
It would be better for you to use one of the many videos available for setting up VLAN on the Orbi, so you can follow as you go.
This link and other links available that may help:
