OrbiOwner20
Mar 27, 2020Follower
Orbi RBR40 and IoT VLAN
Hi, I’m looking to set up a separate VLAN for one of the wired ports on an RBR40 for IoT devices so they’re isolated from the rest of my Wired network and can just get out to the internet. After mu...
Mstrbig
Aug 24, 2020Master
luckyaussiebob wrote:
Just found out about the vlan and now I am more confused. If I can get a seperate '3rd' network from the existing Orbis that would be great.
If you are talking about a totally separate Subnet network, you can plug anothe Orbi router or any router for that matter, into one of the LAN ports of the Orbi router and set it up as a full DHCP server with wired and wireless capabilities. If properly configured, any device you connect to that router will be on its own network.
CrimpOn
Aug 24, 2020Guru - Experienced User
Mstrbigis correct. The practical issue is that customers purchased a mesh network (Orbi) because they needed more area covered than a single WiFi router could manage. Many IoT devices appear to contain inexpensive 2.4G radio chips because they transmit very little data. Perhaps a single WiFi router would "cover" enough area. Otherwise, this solution is going to require another mesh network.
The Orbi "Pro" product provides multiple SSIDs, including one specifically intended for IoT devices. (Four SSIDs total: administration, employee, IoT, and Guest).
