AMExtreme
Nov 22, 2019Aspirant
Orbi RBR40 and RBS40
I have Virgin media 200Mbps internet and if i do a speed test from a device using the RBR40 router i get the expected 200Mbps download speed. If i connect via my RBS40 satellite i only get betwee...
Nov 22, 2019Guru - Experienced User
What is the Mfr and model# of the ISP modem the NG router is connected too? Built in router here by chance?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Has a factory reset and setup from scratch been performed since last update?
