AMExtreme
Nov 22, 2019Aspirant
Orbi RBR40 and RBS40
I have Virgin media 200Mbps internet and if i do a speed test from a device using the RBR40 router i get the expected 200Mbps download speed. If i connect via my RBS40 satellite i only get betwee...
CrimpOn
Nov 22, 2019Guru - Experienced User
AMExtreme wrote:My satlelite is connected to the network via 2.4GHz as a device (doesnt appear as a satellite on the network) - as confirmed on both the iOS orbi app and through the orbi web login on my main Mac.
That is definitely not what it should be. Perhaps do another "factory reset" on the satellite and then use the Orbi web interface "Add Orbi Satellie" (bottom menu item on the home page).
