kproth
Jun 19, 2018Tutor
ORBI RBR40 Block DNS Bypass
Would like to block direct access to external DNS servers -- requiring all users on my home network to flow DNS through the Orbi router. Found the Advanced option to block Services, and tried blocki...
Jun 19, 2018Guru - Experienced User
I would contact OrbiPhilip via PM and have help help you...If what he mentioned in that linked post doesn't work for you...
- OrbiPhilipAug 09, 2018Luminary
I am not running it now (v2.1.4.16), but I was at the time. I set my block range equal to my DHCP scope, which was x.x.x.100-200.
I am not running it now (v2.1.4.16), but I was at the time. I set my block range equal to my DHCP scope.
P.S. This message editor is awful- kprothAug 14, 2018TutorI tried again. Used a narrower block range, encompassing just my DHCP scope. Still no bueno -- it blocks *all* DNS access, including requests sent to the router's IP address. I only want to block requests being sent out to the internet. But since there's nowhere to specify which *DESTINATION* IP range I want to block (or which destination IP's I don't want to block) this doesn't appear to be an option. @Netgear: please make the service blocking smart enough not to block services that the router is providing...
