kproth
Jun 19, 2018Tutor
ORBI RBR40 Block DNS Bypass
Would like to block direct access to external DNS servers -- requiring all users on my home network to flow DNS through the Orbi router. Found the Advanced option to block Services, and tried blocki...
Jan 10, 2019Guru - Experienced User
Have you tried the methods mentioned in this thread?
Might ask OrbiPhilip for more help.
thorax wrote:
Has anyone found a way around this yet? Blocking Services prevents devices from even communicating with the router over port 53.
thorax
Jan 10, 2019Aspirant
Sorry, I assumed that would be clear. Yes, I have. It blocks *all* DNS requests, just as was stated up thread.
- FURRYe38Jan 10, 2019Guru - Experienced User
DNS is assigned to port 53. So any configuration to block DNS will be bloced on port 53.
- thoraxJan 10, 2019Aspirant
That's not what the help page says. It says it blocks *internet* access. So therefore I should still be able to communicate on port 53 on the LAN, but I cannot.
You might send OrbiPhilip a PM to see if he can comment on this..
