JRSydney
Sep 19, 2022Follower
Orbi RBR40 Blocking all Websites On Wireless Mode, not Hardwired
Hi all. Yesterday for some reason and after returning home from a month being away, our iphones started to display a message that gmail could not connect to our gmail accounts , stating the ser...
michaelkenward
Sep 20, 2022Guru - Experienced User
JRSydney wrote:
Yesterday for some reason and after returning home from a month being away, our iphones started to display a message that gmail could not connect to our gmail accounts , stating the server was not secure.
Have you restarted your network again?
Did your iPhone update itself while you were away?
Has Gmail changed its security settings during your absence? They love playing with their system.
All wired devices are okay and a Surface Pro connected by wireless was okay too. It only seems to be Apple products.
Netgear isn't smart enough to make subtle changes to products that pick on different brands. Have you looked in the Apple support world?
Did you find this?
NETGEAR Mobile Applications and Apple Devices FAQ - NETGEAR Communities
I had to pay for support and after a restart, seemed to work okay. The problem again returned this morning and I honestly can't be bothered waiting on support and another hour of Level 1 tech to say restart the router again.
Was that Netgear support or something you found with a web search? If the latter, it may not have been Netgear you talked to.
What did they ask you to do?
