roarty58
Dec 22, 2020Guide
Orbi RBR40 Blocking Duo Mobile Authentication
I have the Orbi RBR40 router (sorry the recommended model box didn't offer this as a choice) running Router Firmware Version V2.5.1.22 (latest version I can find). My work uses Duo Mobile for authe...
Dec 22, 2020Guru - Experienced User
Do you have Armor or Circle enbabled?
I would contact the mfr of this Duo app as well to see if they have any information. Orbi doesn't block much from the LAN side unless you have a security app running like Armor or Circle which may block.
