Dan0785
Dec 13, 2024Aspirant
Orbi RBR40 cannot stream Hulu
So for some reason, it appears the Orbi I have is doing something that prevents hulu from streaming, and I cannot figure out why. I recently signed up a few weeks ago during the black Friday special ...
CrimpOn
Dec 13, 2024Guru - Experienced User
(please excuse my ignorance....)
Is it correct that the Hulu subscription can be used to stream on any device that can run the Hulu app (such as Apple and Android phones/tablets, laptops, computers, etc.)?
What happens when you attempt to stream on devices other than those two televisions?
p.s. It seems sort of cruel that Hulu is able to stream three commercials with no problem but throws an error when the content you want should start.
Dan0785
so, i get the same issue on my 2 laptops and my cell phone. however, when i take my phone off wifi and use mobile, it works
- CrimpOnDec 13, 2024Guru - Experienced User
Thanks for taking the time to perform these experiments. The behavior is exactly the same?
- Hulu app connects to Hulu.
- Credentials are accepted.
- Can browse to different programs.
- When a program is selected, commercials play just fine.
- When a program should begin to stream, error P-Dev313 appears.
