jclark0108
Jan 23, 2020Star
ORBI RBR40 connects to VPN but not remote desktop
I am having an issue where my ORBI router connects to my VPN but not my remote desktop. Any ideas how to fix this? I have a RBR40 - which was purchasd from Target or Walmart. I read that it could ...
CrimpOn
Jan 23, 2020Guru - Experienced User
More information will help. There are two computers. One is trying to access the Remote Desktop on the other. Which computer is on the Orbi LAN (Local Area Network) and which computer is on the WAN (Wide Area Network) side, i.e. "somewhere else"?
- jclark0108Feb 05, 2020Star
Sorry for the delay. My set up is very basic - I have a laptop that is connected to my WIFI through my ORBI router. I can connect to my VPN. However, I can not connect to my remote control desktop (which requires the VPN connection).
Hope this answers your question. Again - not realy techy.- CrimpOnFeb 05, 2020Guru - Experienced User
This is a good start. A laptop connected to the Orbi wants to open a Remote Desktop to a computer that is "somewhere else" (not also on the Orbi LAN), correct?
In that case, no ports need to be opened on the Orbi. There should be VPN client software on the laptop that connects to the remote VPN server where the other computer is. When the laptop connected to the Orbi opens a connection, that automatically establishes the ports that are needed.
My guess is the issue is at the remote VPN end. Are you able to make this work from a different location, such as a friend's house or a public WiFi (Starbucks, etc.)?
- jclark0108Feb 06, 2020Star
So oddly, the only place I have issues connecting to the Remote Desktop through my laptop and VPN is on my home network. Everything works fine at local libraries, Starbucks, Paneras, etc. Again - connects to my VPN at home - just can't get to the Remote Desktop.
