jclark0108
Jan 23, 2020Star
ORBI RBR40 connects to VPN but not remote desktop
I am having an issue where my ORBI router connects to my VPN but not my remote desktop. Any ideas how to fix this? I have a RBR40 - which was purchasd from Target or Walmart. I read that it could ...
CrimpOn
Feb 05, 2020Guru - Experienced User
This is a good start. A laptop connected to the Orbi wants to open a Remote Desktop to a computer that is "somewhere else" (not also on the Orbi LAN), correct?
In that case, no ports need to be opened on the Orbi. There should be VPN client software on the laptop that connects to the remote VPN server where the other computer is. When the laptop connected to the Orbi opens a connection, that automatically establishes the ports that are needed.
My guess is the issue is at the remote VPN end. Are you able to make this work from a different location, such as a friend's house or a public WiFi (Starbucks, etc.)?
jclark0108
Feb 06, 2020Star
So oddly, the only place I have issues connecting to the Remote Desktop through my laptop and VPN is on my home network. Everything works fine at local libraries, Starbucks, Paneras, etc. Again - connects to my VPN at home - just can't get to the Remote Desktop.
