marbran3
May 31, 2020Aspirant
orbi RBR40 constantly drops
I have now had my Orbi RBR40 for 1 year. Interestingly, just after the 1 year mark for support, my router keeps dropping my internet. It will work for 5-15 minutes, then just drops. It was great up u...
marbran3
Jun 01, 2020Aspirant
FURRYe38 I don't use a router and never have since I got my Orbi. My internet plugs directly into my Orbi. I do have neighbors with Wi-Fi, but our lots our 1/3 acre so they aren't super close, and they've been there the whole time. Honestly, the only change for the last year is the Orbi is 1 year old. There haven't been any other changes.
Jun 01, 2020Guru - Experienced User
Ok just asking. Since ISPs are varied and have various Modem HW, nothing is standard when it comes to ISP HW. Thus one reason why we ask.
Hopefully a factory reset should resolve this.
- marbran3Jun 01, 2020Aspirant
FURRYe38 No problem. I'm happy to listen to all options. Firmware updates messing with things, tends to make the most sense.
- FURRYe38Jun 01, 2020Guru - Experienced User
Yes. and then again, some don't see problems after a FW update. Seems like a mixed bag with Orbi ever since. No idea why some have problems after a FW update while others don't. It's crazy to say the least. Usually resets do help those that have problems.
