Slapshot88
Mar 19, 2022Aspirant
Orbi RBR40 Disconnect
I have one RBR40 and three additional satellites. This has been running flawlessly for a few years. Recently we have been having issues in that the ORBI disconnects from the modem. Now, it has disconn...
Mar 20, 2022Guru - Experienced User
Routers can go bad. Doesn't mean yours has though.
Whats the router actually doing? (led's, ping, etc)
- Slapshot88Mar 20, 2022AspirantMost of the time the LED is either flashing white, or no light at all. When trying to access via the ORBI app I constantly receive the message “trying to reconnect” or “We can’t find your ORBI”
- plemansMar 20, 2022Guru - Experienced User
what happens if you hardwire a pc/laptop into the orbi?
Are you able to access it?
What modem/gateway are you connecting it to?
- Slapshot88Mar 20, 2022AspirantNothing happens when I plug a laptop directly into the ORBI.
The ORBI is plugged into a Frontier router (Arris model# NVG468MQ)
