cacree
Aug 18, 2021Aspirant
Orbi RBR40 Disconnects
Hello all. Frustrated here and looking for some guidance.
I have an Orbi RBR40 and 3 RBW30 satellites purchased new in late 2017. This system has been flawless and has worked wonderfully up until about 3 months ago. Started with random disconnects, now has become a daily issue. Usually multiple times a day. The router will usually come back online by itself after about 10 minutes, or if I do a manual reboot. Nothing has changed in my house, router/satellite location etc.
I have upgraded the firmware on the router (v2.7.3.22) and satellites (v2.6.2.6) and have done a full factory reset. Worked good for a couple of days and then back to the daily disconnects. All default settings for the router. Modem is a TP-Link TC7650 purchased by me (not Xfinity provided). Modem is not losing connectivity when this happens.
Any advice would be greatly appreciated. Thank you!
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Traffic Meter, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless SettingsOne User Experience/Configuration:
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026- cacreeAspirant
Thank you so much for your response. I have answered your questions below. I tried your suggestions with no luck. Still getting disconnected multiple times a day. Very frustating and interfering with my job. Any further help or suggestions would be greatly appreciated. Thank you!
What is the size of your home? Sq Ft? 1800+ sq ft
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS📡 to begin with depending upon building materials when wirelessly connected. All connected within 30 ft of each other.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many? Have tried all channels suggested. Doesn't seem to make a difference. 2 wifi neighbors I can see.Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings. Beamforming, MIMO amd WMM have all been all enabled.
Armor, Circle, Traffic Meter, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s). Under Advanced Tab/Advanced Settings/Wireless Settings.Armor, Circle, Traffic Meter, Daisy Chain, Fast Roaming, IPv6 all disabled. Coexistence set to 40Mhz. Short preamble set on both 2.4 and 5 ghz.
What happens if you turn OFF ALL RBWs and just use the RBR alone?
Do you see any top ring LED turn ON on the RBR when the RBR disconnects?
