Toddk1223
May 01, 2019Aspirant
Orbi RBR40 Dropping internet every 10-15min after firmware upgrade
I am not a tech guy. I purchased the orbi RBR40 with 1 satalite, for Alexa, and smart TVs in our house in May 2017. Since i updated the firmware on the router on 4-29-19 to 2.3.1.37, the connection t...
Toddk1223
Technicolor Modem from Spectum Model TC8717T.
I dont have a PC to do the Process recommended. I WAS ABLE TO TALK TO SOMEONE AT SPECTRUM! The tech person updated "the bridging" for the modem. I am concerned that i will not be able to fix this issue if it continues because I do't have a PC.
May 01, 2019Guru - Experienced User
Yes the ISP modem has a router and wifi built in already.
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ or IP Pass-Through for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Do you have a family member, friend or neighbor how migh have a laptop with a LAN port you could barrow?
